I'm working with an lx,betapack, juggler setup and wondered if anyone might be able to say if it's possible to patch the different fitting numbers (points) to a single channel (fader). at the moment i have 12 points - 6 across 2 lx bars, so each is already corresponding with it's own fader.
Page 1 of 1
juggler - patching multiple fittings to a single channel ? patching multiple fittings to a single channel ?
#2
Posted 05 January 2010 - 10:30 AM
The Juggler does not have a DMX patch function, however if you have Betapack3 dimmers, then you can use the DMX patch function on the dimmers to achieve what you want.
If you want to simply raise and lower all 12 channels together, then you can just use the master faders on the Juggler.
Page 1 of 1
Sign In
Register
Help
MultiQuote
